That's the worst texture pack I've ever seen.![]()
It seems that the entire linktart server has died..............![]()
OChestDump allows you to dump the contents of your inventory to a container, or to dump the contents of a container into your inventory, or to swap the contents of a container with your inventory, or to sort a container.
To use, type "/ocd swap", "/ocd loot", "/ocd stash", or "/ocd sort" in chat while looking at a chest or dispenser. Typing "/ocd" in chat will bring up the help for the command.
Loot fits as many items from the container into your inventory as possible.
Stash fits as many items from your inventory into the container as possible.
Swap simply swaps the items from the container and your inventory.
You can add an item name or ID after swap or loot to exchange only the specified item.
Sort allows you to sort items by name (default) or total amount of items.
Logged back into Minecraft yesterday after some time out and now it just crashes to a black screen randomly. I've deleted everything to do with Minecraft and reinstalled it but it still happens.
Why and how can I fix it?
Install the 64bit Java client, this should be in the OP it gets said so often lolLogged back into Minecraft yesterday after some time out and now it just crashes to a black screen randomly. I've deleted everything to do with Minecraft and reinstalled it but it still happens.
Meh, go away for a few days to find that someone has flooded part of my basement with lava.![]()
Cheers whoever / whatever ruined my house (Y).
CBA after last night, see you when I can be bothered to play again :/
Papa hopefully the correct amount of lava has been removed. Have a looksie & let us know if you can. Cheers.
Sign back in please, your house is there but may be missing a part.
It was an admin error on my part & my apologies. I was undoing damage at Papas & mistakenly used the wrong command.
Edit - The small building over/with a pool is broke- If you log back in i'll help you rebuild it.
