Surely as the speed goes up the latency will come down, I understand it is never going to be instant, there will always be latency but I would have thought it will get to a point were it is so low that it is almost instant. I may be wrong as I am not an expert in this area.
Bandwidth and Latency are two separate(but entwined) things, do not get the two confused.
Since 2000 my pings have stayed relatively the same, except last year I went from 2Mb to 8Mb which put me on the next generation network in Jersey, using a new submarine cable laid to the UK, it slightly improved however my ping to a server in texas for ARMA1/ARMA2 went from 170(always was 170) to 130.
What matters most is how the data you send and receive is handled by all the, for a lack of words and to make it simple, "hops" it takes.
You could have the best latency you'll ever get to a location but if someone between you and them decides to perform poorly, then it will suffer.
However, when latency does come into effect when your bandwidth begins to saturate, if you are using all of your bandwidth to download say a film and then decide to play a game of Counterstrike online, the data required to have decent ping is going to be fought over, unless you've set up Quality of Service(QoS) to allow programs you want, have priority.
Beyond a certain connection, no more will help unless switching to a higher speed puts you on a better network.
I'm no expert either but I know enough to explain it simply
