Has anyone found a screen protector they would recommend? Never used one before. My main concerns would be whether it is as smooth as the phone surface (for swiping etc) and whether it "dulls" the screen in anyway.
I saw the picture of Khaaan's one further up, but the screen looks duller and a bit more grainy with it on (it could be the photos but they look like they are taken in similar conditions and I am guessing the owner is a bit of a photographer so unlikely to be the camera etc).
rp2000
@Khaaan, regarding the official car mount.
Could you tell me roughly how long the charging cable is please? as my cig lighter is behind my handbrake and I'm wondering if I am able to route it behind the dash or not, thanks.
Guys what would you say is the most durable complete-cover case for the SG2?
I need one for when I go mountain biking and the phone goes in my backpack, I have the official Samsung back cover one but it'd be nice to have some more protection.
Looks great although I think one which has front protection too would be better?
What is the actual part that holds the phone? I see it also accommodates the case, is this secure?
Thanks
I drove 200 miles on Saturday with it, no problems at all so yep, secure
The part that holds the phone (with case) is this holder:
http://www.ebay.com.au/itm/UNIVERSA...ccessories&hash=item1e628908f5#ht_2882wt_1135
You could just use that holder as is because it's pretty rigid by default but mine was a bit dodgy on the suction cup as the twist lock on it worked itself loose while driving around as it wasn't as tight locking as it should have been hence why I modded it into my DIY mount via the Garmin suction holder.
Also, anyone getting the Nillkin case keep an eye on your case's screen edge on one side, I just noticed something on mine:
http://robbiekhan.co.uk/root/photos/stuff-room/sgs-ii_nillkincaseissue.jpg[img]
The top left lip slopes down getting that corner front close to the edge. Some kind of manufacture defect by the looks of it.[/QUOTE]
Awesome, thanks. My Nillkin case is exactly the same. My other two (case mate barely there and the official one) are fine though.
Anyone know anywhere to get the official case now?
Sold out on the ebay/amazon links that had been posted and cant see it cheap anywhere now!
Can someone recommend me a decent screen protector?
It's a bit more compact in design and takes up less space in the glove box and when in use.
