i will make it bigger as the server gets bigger and played on more, i want to have a quest to hell now to get hellstone, will wait till theres a few of us to go though as i die in around 1 minute now.
Anyone using mumble whilst doing all this?
Bought the game last night - completely addicted to the game. I didn't realise what the wall bricks were for and built my house inside a mountain!!!! Going to start building all over again and also plant the acorns close to the house for recycling the trees.
I've made a route right to the ceiling of the level ontop of the tower (right hand side) using discretely placed ash blocks. If you jump from it you can get to one of the floating islands![]()
I did jump off it, ...splat![]()
Get a lucky horse shoe! You don't get fall damage then![]()
Can you only have 1 piggy bank?
I heard it links them together virtually rather than gives you twice the space etc.
Yes.
If you buy two piggy banks, both will hold the exact same items. This works across worlds, so you could have multiple piggy banks on the same world (providing access to the same items), or you can have multiple piggy banks on different servers, all of which hold the same set of items. It's basically an extension of your inventory space.
Thanks.
Another quicky: is there a way to consolidate my money? I have loads of 100 coppers stacks in my chests![]()
stand near a work bench with the money in your inventory, and you'll get the option to convert 100 copper into 1 silver, and 100 silver into 1 gold (also, the option to do the opposite, ie 1 silver into 100 copper).
Best bet is to stand near the workbench, press escape to get the build menu, then click on a piggy bank. You can now convert money and move it between inventory and piggy bank at the same time![]()
Ah nice! Will try this when I get home. So you don't have to place the piggy bank on the bench to access the coins inside?
just in click-able reach - you need to be able to click on the piggy bank whilst in build-mode with the bench. Obviously, piggy-bank-on-bench makes this much simpler![]()
