Note that if you have built a single-block bridge (even one composed of wood platforms) in the sky in search of Floating Islands it is possible for a meteorite to land on that bridge and you will end up getting only a small amount of Meteorite. It is suggested to destroy any paths in the sky before smashing a Shadow Orb in order to get a normal amount of Meteorite.
Note also that when it is stated that the Meteorite can land 'somewhere on the surface,' these locations can include both the Floating Islands, along with the Dungeon. Blue be with you if the second one happens.
Well I just purchased this game, I must say it's a little odd but quite fun (in an old fashioned way).
I had to watch a number of video tutorials on youtube because I didn't have a clue what to do at first.
Any advice? I've made a few houses and a few shafts, not that deep perhaps 100 tiles at a guess. Should I just keep digging until I find something interesting?
I keep running out of torches.
Well I've been digging for 6 hours and I've not found anything yet, just a few pots and small amount of gold... !
I've literally seen two zombies, three blue blobs and one green blob in that time - doesn't seem like many enemies to me?
Enemies can only spawn outside your screen. Originally the game was fixed at 800x600 which made enemy encounters much more frequent. If you are using 1920x1080 you will rarely see any.
I use 2048x1152 (native).
...does that mean I'll rarely ever see enemies? That's rubbish!![]()
Where can I find shadow orbs?
you can find the sky islands, the dungeon, smash some shadow orbs and fight eater of worlds, find the jungle, keep digging to hell and try mining more ores, go for gold armour, or necro is quite easy if you collect bones and webs. id go on terraria wiki and have a look at some of the gear you can get/make. also download the terraria map viewer if your a bit stuck, it will show you the whole map, where everything is.
yes the bigger the res, the less monsters will spawn
Enjoy!
