I was thinking about trying this one.
Any downsides?
Had carpy battery life initially but I think that got fixed by a few power cycles or it might have been the updates I've flashed since then. Otherwise seems pretty good.
Any downsides?
> 8GB in size
> 9000 kbps in bitrate
Some PCs cant even handle full HD in that quality... yet this little handheld joy ploughs on through it and taunts you with sexy crisp images while it does it.
Oh... and it played the file instantly upon clicking play. Skipping took about 1-2 seconds, same as on my machine though running an i7.
That's honestly pretty freaking amazing.![]()
I thought files had to be 4GB or it can't play them due to the file system...
yup, me too.
Hmm, very (100%) possible if it's FAT32. rexehuk, any comments?
Worked fine here... Not sure on that one. Others welcome to confirm if you need proof. Could be a modified FAT32 file system with extentions for large file handling.
The file system is EXT4, the storage internal/external SD is FAT32.
Earth[Tera].bin;19414209 said:Quite like the S II but the Wifi is doing my head in, missing my old Nexus One.
