Arma 2: Operation Arrowhead
If you have Arma 2 already then buy OA and you will be able to play them both together. Basically they contain separate maps and OA is a slightly newer version of the game engine
Copy the contents of Arma 2 into the OA directory then load OA and it will play both and you can play all maps. Some servers also require additional mods like ACE
I tried the six updater a while ago to download and install the ace mods, I found it extremely confusing with all the options and just a royal PITA! I ended up installing it all manually!
One thing I've been unable to find, and to enjoy, is firefights in this. I used to adore the original OFP for that, Arma2 just seems to lack it :( suggestions?
The amount of user made missions and campaigns (top quality) are lacking too I feel....
I suggest you use the new six updater, it is much improved in terms of UI and functionality. No more yukky web interface running off ROR.
http://www.six-updater.net/p/download.html
If you are not finding good firefights... then you're not playing the right missions. Arma 2 is all down to the mission maker in terms of experience, not many people focus on the environment which is a huge deal breaker for me.
I made this a while back (v2 currently in development) - May this will add a bit more spice to your missions:
Do you have ACRE and ACE installed Rhysduck? I might be able to get you into our sunday operation today, maybe you will enjoy it.
Website: http://www.havoc-company.com/default.aspx
You would need to download our havoc pack though which is a few GB, we start at 7PM GMT.
The closest Ive seen to a firefight is the video I posted above. It requires a city which OA does have but theres no way arma plays as fluid as a normal fps
Anyone know where I can get all the expansions ,dlc and the original game in a pack or cheapest? Tried Arma2 free and loving it but quite a few people ruining the game tking etc
Like my fellow buddy rex as pointed out, six updater has had a massive change and is soo easy to install mods on it now
Best experience with arma is joining a group who are organised and tell you what mods to get, nothing beats it in my opinion, so much so I never play public any more it's that good.
My mates been doing my head in telling me to get this expansion. I have Arma2 but it didnt run very well, but now I've gone crossfire 5850 so you guys think it will run better? Has this expansion been optimised?
