Does it work ok otherwise? Didn't think the sliders would work being a touch device etc.Just trying it on an iPad. The red warning messages could do with being near the submit button, or relative to the screen. I pressed it a few times and nothing happened and because it was scrolled down, didn't see the 'you must select a manufacturer' message.
Will sort this out for you, got a few models that don't line up correctly across all sites.Not sure if its been noted already but it doesn't seem to produce / search for all results. For example, searching for A3 sportback and <£6000 only produces 1 car which all 3 website searches ticked.
I like the concept, but "searching all the major car ad websites" doesn't make sense when it only searches three, it sounds over ambitious
Eh? Just use the filter
Its searching the 3 that are worth searching, i think it would just over complicate it if he added gumtree loot and all the rest of the odd lots.
Hunting around trying to find what others are doing in this area and found www.netcars.com
Anyone had any dealings? They seem to be taking on AutoTrader with hot social marketing and plenty of SEO techniques. Looks to me like they even have paid bloggers generating content. Has anyone heard of them?
.Thanks for this, didn't realise what people were talking about before when they mentioned it as I always searched for <100 miles and no cars were less than ten miles.Found a minor niggle. When I put the search down to 10 miles and sort the results by distance it sorted the results 10/6/7/8/9 and the other way 9/8/7/6/10. Other than that the site looks great![]()
