go in to Windows firewall advanced settings find Steam in the Inbound rules and delete it and restart steam when windows comes up say allow access
second go to your routers login page which will be something like 192.168.0.1 all the details should be on the side of the thing like login info ect ect
Go to port forwarding and add those ports I gave you a few pages back that steam uses to make sure its not that.
And yes it can be a intermittent problem.
You might as well try it, it has worked for some users
if none of the above work it might be sky a few other users have had connection problems with them
Had another idea go test your connection on
http://www.speedtest.net/
