- 23 Dec 2009
- RG8 9
Does anyone know a fix.
Better fans.
No like the motherboard doesn't change the fan speed.
Thought you could change the fan speed through speedfan ?Should I set it to full auto in the bios. MSI boards also have this smart fan thing in the bios for cpu coolers should I mess around with that.
Speed fan only llets it go at the percentage I put it at and then the cpu fan speed doesn't change.
Set the CPU smart fan in the bios to 50/37.5% until the CPU reaches 50/60 degrees.
The fan is still prety loud after changing the settings in the MSI bios. I don't think it's changing in speeds as well.
Check using speedfan don't guess
If it hasn't changed try disabling smartfan auto completely as I initially suggested
Still a bit loud. Will make another change
When you change it in the bios, what have you set the other fans to run at?
They are at 100.
I thin those ones are silent.
?Don't you think 50 is low.
