Computer is loud.
Should I set it to full auto in the bios. MSI boards also have this smart fan thing in the bios for cpu coolers should I mess around with that.
Speed fan only llets it go at the percentage I put it at and then the cpu fan speed doesn't change.
Set the CPU smart fan in the bios to 50/37.5% until the CPU reaches 50/60 degrees.
Yeah if you want to be the one in control then you disable 'auto' in the BIOS
Ok doing that now.
I changed to those settings.
This is off topic but when I boot up the system there is a little mark in the top left hand corner and the number 98 in the bottom right hand, it stays there for a few seconds. What is it.
The fan is still prety loud after changing the settings in the MSI bios. I don't think it's changing in speeds as well.
Check using speedfan don't guess :p
If it hasn't changed try disabling smartfan auto completely as I initially suggested
Problem is fanspeed keeps changing it how do i stop it from doing that?
Blank that seems like it did work. Still a bit loud. Will make another change
