Thanks guys! Thought I'd test some temps after the loop was ready, but with only the quad rad running as I hadn't sorted cables for the top rad yet.
CPU
Quad with 4 x GTs running in silent, and Triple on passive...Linx first. 2500k at stock, after 6 passes the hottest core hit 49C tops on load. Not bad...but the gpus weren't been stressed and I'd hoped to get a bit better.
GPUs
Testing GPUs in furmark. What the ****? Bottom GPU is 20deg idle, top GPU is 30deg idle which is ok (top gpu is outputting an image). However, under full load, the bottom GPU goes up to 23deg, and the top GPU hits 65!!!
My first thought here was - dammit, I've ballsed up my crossfire. Ran Heaven benchmark and same result. Then ran a couple of games that I know work with crossfire, still no temp increase on the bottom GPU. Disabled and enabled crossfire, tried new bridge etc. Uninstall, reinstall drivers + latest CAP, same result. Tested bottom gpu and it works properly, outputs image etc.
What the ****??
Like an idiot I only then checked fps with crossfire enabled and disabled, and it turned out I was getting double fps with it enabled. I only then checked the load for each card, and it turned out both were at 100%.
Basically, my loop is cooling the bottom card so that at 100% load, temperatures only go up by 3degs, but because of my 'ghetto crossfire link
', flow to the top card is being restricted massively, and load temps there are very high indeed. So, sort out that link and hopefully gpu and cpu temperatures will both improve
? Argh need to drain and redo that part of the loop at least
