Silverstone Fortress FT02B-W Owners, Your thought's please!!!
My only gripes really are that the HDD caddies are a bit flimsy, and the top USB connector assembly feels a bit cheap.
Yeah I thought that too, but when you actually have a HDD in them they are pretty solid.
How was the cable management of all the hotswap adaptors. not looking forward to doing that.
Ah.
What difference does it make?
Could it affect overclock?
Just working on some photo's now, will reboot when done and swap them over.
How did you guys find cable management? I had a bit of a struggle, and now getting the side panel on and off isn't that easy because of the amount of cables behind the motherboard tray. One problem I had with the case was the distance between the PSU and the HDD bays and SSD mounting point, I was only just able to get the cables from one to the other, though that could be Coolermaster's fault as much as Silverstones.
I will put that as 1 of the cons of the case. needs about an extra quarter inch behind the motherboard tray.
But I had no problems getting my cables to reach allt he way across to the HDD and SSD mounts.
My PSU must have shorter cables than some other ones then. The only other complaints I have are that the mechanisms on the tool-less drive bays aren't quite as good as some other cases (I find that the optical drive blanking plates are a bit loose), and the cover for the front headers feels a bit cheap.
I'm extremely happy with the case other than that though, it's got great cooling, while remaining very quiet, and the general build quality is superb.
I am glad someone is happy.
My order fell through today when the suppliers *not ocuk* have given my case away to someone else after i paid for it a week before??.
I am waiting a phone call atm for a explanation, not happy :mad: taking the day off just to be told the night 8pm before it not coming.
Already Chris, thats abit brave. With this case never saw the need for watercooling. esp with sandybridge gear, as it runs really really cool anyway.
What you planning on doing?
You'll struggle to find a location for the pump though. In the drive bays, or in the Hot Swap bay. That's about it.
Try the MM mate. Some bargains to be had. I'm about to sell some gear and there's a lot of WC threads on there atm.
