Bradmax57: is it possible to fit a Asus GeForce GTX 580 DirectCUII into arc mini?
My arc mini build starts next week but with a 2500K instead. I would have wanted the H100 but couldnt justify it since I already have a coolit eco.
Would you be able to mount the rear fan on the inside if you rotate the H100? Also did you use black tape as make shift cable braids?![]()
No i dont think you could unfortunately, i just used some black tape to cover the unbraided parts of the cables![]()
Do you really need a rear fan once you have the dual fan H100 sucking out the top?
Looks a nice case. Have been eyeing it for a while
I dont see why you cant rotate H100, are you really sure? Maybe just a little dremel and you can rotate and get the fan inside.
Spose not, but I had it anyway
99.99% sure mate, even though its not as big at that end as to the end with the pipes coming out the rad it would still hit the fan on the rad, the only way around it would be to use slim 120mm fans, it does state on fractals website that if a 240mm rad is fitted you loose the 120mm rear fan.
Does it fit normal size PSU's? Or do you have do find a smaller one
big psus might mean you cant use a fan in the bottom tho but its not much of a prob tbh
Finished with my build now, just testing it. I think I'll post the pics in here instead of making a whole new thread
