- 11 Oct 2005
- Derbyshire
thank you Sin Chase, you like your flowcharts
it does help.
Is your cable solid core? If not your going to need modules designed to take stranded cable.
Thanks. I appreciate your guidance. As not installed the cable yet. Would prefer to make 110% sure I have it spot on before routing through walls etc and crimping ends on.
I have bought 12 RJ45 sockets the other day from a local electrical specialist. No idea if there for solid nor stranded core.
Perhaps I should look around on line for some solid core Cat5e then.
I can always use the 30m from OCUK for something I would think.
You can safely extend a fair distance assuming you are filtering at the BT master socket, which by the sounds of it you are with an ADSL Nation faceplate. I extend about 15 metres and have no loss of signal quality - train at the same speed plugged into my master socket as I do extended.
You can run an extension with proper 'BT style' 5mm cable or just plain old CAT5. It becomes a little more complicated but it's more than feasible.
ALA:
