- 11 Oct 2005
- Derbyshire
Bremen1874.
You mentioned 'only one wall plate'
I only bought one wall plate for the time being as not 100% sure what I will do yet.
At the moment the Cat5e runs from Master socket -> outside -> into attached garage -> into understairs cupboard then through a small hole to the back of all my AV gear in the lounge. (I actually ran x2 cables) one for in case of any future problems. Plus I can in effect stick a RJ45 on each end and use it as a long patch lead.
Lounge comprises of: router / ps3 / squeezebox / + in the future a HTPC
I don't know what next is best. Perhaps a patch panel in understairs cupboard?
or just plug everything into back of router and job done. But that means a lot of messy wires.
I don't understand patch panels. Don't understand what gets wired into the back of them. Do you have 2 patch panels? 16, 24, 48 port? guidance on this would be lovely.
In time I also want to send 1 or 2 cat5e cables upstairs into the small bedroom which houses a desktop pc as well.
I also have a Wi-Fi enabled network printer which is currently using wi-fi for connection.
Ideally it maybe nice to have a lot of the back bones of the computer stuff in this cupboard.
Perhaps you would all like a pretty photo of the cupboard then you can all help tidy it up for me via this forum.......?
