The New Cases Gallery
With 20'c at the case intake both the CPU & GPU idle at 30'c.
After a few hours of Prime 95, the CPU hits 58'c. Never seen it go over 50 in normal usage though. GPU peaks at 44'c playing Crysis 2 but that is with stock speeds, I need to see what she can do. Was fed up with the turbojet cooler that the card comes with...
Lol pwned.
Forget what the clock is called but if you google "big LED clock" you should see something similar. Got it from a well know electronics store.
Yeah I was unimpressed so much that I returned it 24 hours later!
I'm going to find a way to tidy away the GFX power connectors, I must as it's now bothering me being the only cables not tidied away!
Edit* Done, easier than I first imagined!
This is why I like my 650D and well Corsair cases in general, you can make them look so tidy with relative ease.
Built this when the 6950s came out. Thought I'd better post pictures of it before I break it down to sell it tonight.
It's very quiet - 7 fans all at 12 volts and 2 smaller pumps rather than one big one.
Sweet! i had no idea you could move the HDD cage back. i might do this :P
http://robbiekhan.co.uk/root/temp/_MG_2219.jpg[img][/QUOTE]
You definitely need to get something sorted with those fans now, get some black Apaches on there at the very least!
The Noctuas?
The Noctuas are staying!
Unless you can find me fans that are as quiet or quieter and push as much air.
So that's 12dBA to beat, good luck :p
See I don't really fancy splashing £30 on fans just because they're not brown or improve cooling by +£30!
