***The Vapers Lounge***
Status
Not open for further replies.
jmc007 is there a good place to get updates on when the iAtty is likely to be in stock? It sure does cost a lot but I've spent a lot more on atties over the last year or so and have used past there best ones just to save some money.
Whilst extremely bored yesterday. I decided to rub down one of my old tornado batts & attys it was a white one to start off with although more yellow as used at work and had become too filthy to come clean
Love the brass and brushed steel look almost steampunk
I think this should be a standard option tbh looks great although unless I take the battery to bits I can't rub around the button properly :( oh well
Problem is, without any protection it will look horrible in a few days time
Keep your eye on this thread.
Imeo himself moderates and posts everyday.
Wonderful place full of experienced, very helpful fellow vapers. Highly reccomended.
I'll sort something out
I [heart] Brasso
If you can find a cheap way of doing it, ill do it to mine, im not keen on the rubberish black paint on mine.
what are we smoking?
Propylene glycol and/or Vegetable glycerine
both lubricants and what do lubricants do... Generally?
That's right they coat what they are lubricating
So I reckon by giving the rubbed up tornado a quick wipe with PG or VG would be plenty to protect it. so unless your in the habit of leaving your PV outside for a week then I don't think its gonna get wrecked with little to no protection
Ermm PG based stuff, but ive only got the pre-mixed stuff, as for the protection, wont it start to go black and dull? most stuff ive stripped paint off has gone nasty within a few days.
Might whip the dremmel out later and give it a bash, im too lazy to do it manually lol.
Edit. found a tube of Autosol metal polish too :) definatly gonna try it tonight.
Just metal polished it and taken some of the brushed look away. It looks machined. The Brass button shroud and battery end cap are highly reflective.
The whole thing looks expensive now lol just hope it lasts a while before it breaks :P
Brushed atty on platinum battery, looks nice.
Vg vape in a cup, thanks to whoever suggested enjuice, although their menthol ice is lacking a bit in flavour. Loving the big cloudy vape though!
2 days with nicotine free juice. Am not missing cigs at all, but I'm not taking any **** from anyone at the moment. The smallest of things are getting my full fury.
If you require more menthol mint flavour, grab yourself some menthol crystals from any pharmacy. I got mine from boots, you have to ask for it. I think my 5g pot was about 87p. Use sparingly, one whole crystal to 10ml of juice adds quiye a kick; I start off with half of one or less, then build up if needed.
Is there such a thing as Vaping too much? ive gone through 3 tank cartridges today is that ok? 24mg Absinthe :) just so moreish.
Edit - Although in saying that ive got a really bad sore throat today, probably down to the 24mg, now do i try and find Absinthe in 18mg or do i mix a Liquorice flavour of my own (which i have 0 clue on how but ill read up on it)
I'm not a fan of menthol flavours. I much prefer the mint ones. Peppermint being my favourite. Must try some of the Nana mint flavour as that seems quite popular.
Also, anyone fancy helping me with the ecigwizard comp please? Check out their facebook page and vote for me (Paul Harman) in the competition. Would be much appreciated.
Ordered a spare atty from egigwizard on Fri afternoon and it arrived Sat morning - very very impressed with the service...
Also ordered 3 ml sample sizes of RY5 and hypnotic mist, only tried the RY5 at the mo, sort of choc/caramel/vanilla/tobacco mix - its not too bad at all.
Also ordered some vanilla,latakia,caramel,bavarian creme flavourings so I can have a go at mixing my own..
2 weeks now and not missing the fags at all :D
Ok here's one for the experts in the tornado, I leave my tornado fully assembled over night and lay it on its side, but wake up to find half the tank gone and a puddle of fluid, it seems to be coming from the little holes at the base of the atty on both my normal and lr one...is this normal? I thought on its side it was fine? As a result I'm using more fluid than I should be.
I'm guessing you are using a tank? I've had it happen more when on its side than in an upright position. It happens fairly rarely to me, the advice from the vendors is you should dismantle ecigs overnight (I'm far too lazy to myself). There are a number of good reasons thou. It stops the leaking issue if you cap up, removing the atty from the battery saves a small amount of power, letting the atty mavity drain over night is good for it.
Hainv gread most of this thread im interested, if not lot in all the jargon.
Smoking 20 a day i fancy giving this a go.. But all this talk of tanks and other bits is a little confusing..
Whats the best one to buy!
i have been told this is the latest best one?
http://www.vapeescape.co.uk/the-riva-t-tank~191
will this get me up and running and free of too many hassles..?
Thanks..
Thanks..
Hiya,
was quite new to this myself and also a 20 a day smoker.
I'd recommend Liberty Flights and the Black eGo T Type B - 1000mAh PT Kit they have.
Couple that with some 'juice' (the liquid that you use in the device) and you will be off the fags in no time.
I stick to PG juice, it has more hit, the devices themselves go together like this:
Battery - Atomizer - Tank (holds the juice).
I'd recommend only 5ml's of juice of PG range to begin with so that you can try them out, so get a few and then put in an order for the bigger 30ml.
As for strength, I find that the 11mg is enough, but I got some 18mg also.
I had tried 24mg but that is too strong and you don't want to go higher if the lower will cut it.
The one above has a 1000mAh, that will last you a day easily, it has a big tank, probably use two of them, three at extreme in a day.
Tanks - you get 5 blank ones, no juice. Pretty cheap, £2?
Atomizer - you get two. £9 a single, if cared for by cleaning or rotation will last 6-8 weeks.
Batteries- you get two. £15 a single, will last you a few months.
Juice- 5ml, £3, you have to buy that separate.
My order I got one spare atty of low resistance (LR) type B as Type A does not fit the new Ego's as I see that as an easy point of failure:
E Liquid - DV - Coffee Premier Coffee - PG - 5ml - 11mg
E Liquid - DV - Tobacco Premier Tobacco - PG - 5ml - 11mg
E Liquid 5ML - PG - Others Menthol -High - 18MG
E Liquid 5ML - PG - Others Coffee - Medium - 14MG
Electronic Cigarette - Starter Kits eGo - T Black eGo T Type B - 1000mAh PT Kit
Low Resistance Atomizers eGo - T Type B - LR Black eGo - T Type 'B' Atomizer - LR Single
That site is amazing, ordered late Thursday night, added a comment to order and he called me Friday, went out Friday and delivered Saturday.
Hope that helps you somewhat. Post any questions.
Cheers
Status
