*****Official Deus Ex 3: Human Revolution discussion thread*****
Does it really matter that much? It looks like a good game judging from the leaked preview and the reviews.
The performance of the preview was pretty good overall. And it does have DX11 support. More and more often, a lot of the current games being designed on PC for the consoles, then ported over the console.
Check this item: http://www.cinemablend.com/games/Deus-Ex-Human-Revolution-PC-Won-t-****-Poor-Console-Port-34262.html
They usually are pap. I don't care if it's on consoles as long as it has been made properly on PC.
I will be vpning as soon as I get home about 18.45 tomorrow! done it before with things on steam and had mucho success so hopefully this will be the same.
Well, it depends on the port :p
You can't say ALL console ports are rubbish. But it seems to have been developed properly on the PC.
And what exactly is so bad about the console ports? Are you talking performance wise? Or what exactly?
I am just wondering, do the owners of the VPN get to see my personal info, such as card details?
Potentially but usually that traffic between you and steam would be encrypted and generally traffic over a VPN is encrypted to.
NO ;) with VyPRVPN all that changes is your ip address
basically they have a server, your real ip its that server say in the USA and it bounces a new ip address out to the web ;)
Most commonly with VPNs all your traffic will go through their servers and then back out so they could potentially monitor it. There are services that can perform middleman handshaking between 2 end points and then hand off the session and traffic would flow direct but you'd need both ends to be using tunnelling software and thats not very usual with most sites on the internet - off the top of my head hamachi is the only thing that works like this and both end points need to be using the hamachi client.
http://www.thereticule.com/?p=3028
You can get Adam Jensen's coat! But sadly not the awesome one with the subdued floral pattern shoulder pads.
edit: This one!
I want this coat! Are you listening Eidos? This coat!
Stop moaning about console ports in this thread.
this game is not a console port end of.
2 teams where working on this game 1 pc and 1 console, pc version has extended dx11 features aswell built in.
There is all diffrent kinds of VPN some are more protected than others.
if you get your VPN though Giganews you are protected with SSL encryption when downloading or changing ip with VPN.
and yes i will be doing VPN tomorrow no doult about it :D
