with Phenom II if turbo is enable cpu-z only shows the higher clock when the 1,2, ect cores are only in use
on cinebench i get 6.32 pls at 4ghz
i tryed 3.6GHZ but got the same 6.32 pls![]()
.if its true then i really think the extra 2 cores are not giving really any extra performance. but we don't know what motherboard they using.Seems like it's working.
So, what's your verdict on todays benchmarks? I'm sceptical about their validity, but there's no way to be sure.
but cinebench uses all the cores/threads so turbo won't be kicking in. so it has to be manually overclocked to 4.2ghzAt full turbo speed you'll be running 4 cores. So 4.2GHz results, unless manually overclocked, will be a result of 4 cores at that speed. However, the 3.6GHz result would be with all 8 cores at turbo.
Anyway we'll find out soon enough where the truth lies.
According to the slides linked to in the last page or so, Turbo works with 8 loaded cores, it just doesn't go as high as when you're using 4 or less cores. 3.2 GHz rising to 3.6 GHz with 5-8 cores and 4.2 GHz with 1-4 cores makes sense.but cinebench uses all the cores/threads so turbo won't be kicking in. so it has to be manually overclocked to 4.2ghz
the only time turbo kicks in is when a app only uses 1/2/3 or 4 cores/threads
but as i said i'm 99% sure theses are fake
if thats the case then goodAccording to the slides linked to in the last page or so, Turbo works with 8 loaded cores, it just doesn't go as high as when you're using 4 or less cores. 3.2 GHz rising to 3.6 GHz with 5-8 cores and 4.2 GHz with 1-4 cores makes sense.
It's the CPU-Z where it says
Specification: AMD FX(tm)-8150 Eight Core Processor
That caught my eye at first, contradicting names and then stating "Eight Core" seems a bit out of the ordinary.
I hope for you lot waiting for BD, these are fake, however they're new as of today;
