there is info on their website about usb upgrade
To do a manual usb flash of the new firmware you need UltraIso (free Trial) and the Crucial Firmware 0009 ISO-File.
- install UtlraISO
- Open the Iso file with UltraISO
- doubleclick on the 'BOOT' folder
- doubleclick on the 'ISOLINUX' folder
- doubleclick on 'BOOT2880.IMG' file
Now you can see the files of the DOS Image.
You need to extract these 5 files to a subdirectory on your USB stick (by right clicking on each file and choosing 'extract to...' from the context menu).
- autoexec.bat
- dosmcli.exe
- fwa.img
- hdpmi32.exe
- mode.com
After that boot from your USB stick, change to the subdirectory you put the above files to and run autoexec.bat by simply typing 'autoexec'.
That's should do it.
Good luck!
- install UtlraISO
- autoexec.bat
- dosmcli.exe
- fwa.img
- hdpmi32.exe
- mode.com
Good luck!
