Ok a n00b question..
How likely am I to do some damage to my hands from the vibrations on a DAS-6 from a whole days use of a DA? Does damage usually occur after months/years of use?
take the seals off them and use a tiny bit so they aren't new ?
Damage usually occurs while you are doing it, and press too hard and stay too long on the same point.
Keep the thing moving, follow one of the guides on DW and you will be fine. DA polishers aren't nearly as deadly as rotary ones.
Damage to my hands Rob from the vibrations not to my paint![]()
How is this pressure washer? Don't really want to spend more than £100. Would it be compatible with some of the better known snow foam lances?
http://www.halfords.com/webapp/wcs/..._productId_817529_langId_-1_categoryId_165689
Whats the best wax for my space grey E92? Ive got Poorboys natty blue but I want something easier to apply that gives a wet look and a deep shine. Been looking at this, what do you think?
http://www.chemicalguysuk.com/Butter_Wet_Wax_CAR_WAX_WET_LOOK_SHINE_16_OZ_p/buttwax.htm
I checked out 2 new products today, Astonish anti fog glass cleaner and spray n shine detailer.
For £1 each they're a bargain and I honestly can't tell the difference between these and Fast Glass + Meg's Speed Detailer/AG Detailing spray which cost £7 more each.
