- 10 May 2004
- Middlesex
Yep that's correct.
And that wasn't from the epp store but the "dodgy" link?
Why won't mine change...damnit.
Yep that's correct.
I disagree. The Touchpad is still a better tablet compared to all the others that retail @ £200.
It's only when you get into the £275+ bracket that the Touchpad stops making sense.
The Amzon tab will probably change this reasoning over the next month though.
Why won't mine change...damnit.I did order mine 30 mins after you. Maybe I missed the deadline.
Same![]()
Is it worth getting the touchstone charge/dock ?
Same![]()
Ok, I got the price wrong for the iPad 2 price comparison..It would actually cost £100 more than a Touchpad, plus £15 Delivery...
Still, £200 for a touchpad is re-donk-ulous...
Unles I can find one cheap, i am not bothering. Looks like its out of stock in most places, or really expensive in others!
Is £35 on the cheap side? down from £65
Pretty sure it was the dodgy link, I was ordering from loads of places so it may be the EPP one.
Yes. It's as cheap as you will ever get and trust me, once you have one you would never do without one
I got my email from the dodgy link at 12:34 which is one of the earlier ones ive seen on here and mine still hasn't changed!
What time was yours?
All you saying that tablets are just toys etc, its all down to what you want to use it for.
The vast majority are happy with a low spec PC as it does what they want it to but that doesn't make it a toy.
Tablets are great media devices that also do the internet, email, social networking etc the same as a smartphone but on a bigger screen.
Just because you don't want one don't mean others won't.
I've had a zoom since April and use it more than the PC or netbook......
Anyone shine any light when/if Argos get them in stock?
