Deleted member 87287
Really nice build! I was going to get a Define R3 but now I see this I want a smaller case which means more money on an m-atx board![]()
It's about the same size as the R3 though so I'd get the R3, it was moslty the small size that appealed to me as my Antec P182 is so large and heavy!
Finished with my build now, just testing it. I think I'll post the pics in here instead of making a whole new thread
Massive oversight by Fractal imo they could have moved the mount 5cm forward, and I had already dremeled the side so I just put a dust filter over it
Yes I know, need black apaches
Overall, I'm very happy with the case although it is bigger than I was expecting. The fans are all around 800rpm so almost inaudible. The loudest thing is the pump on the CoolIT.
ok, totally getting this case both your builds are awesome,
do you reccomend the CoolIT ECO? i can get a Corsair H60 for the same price
Weird, I found my supplied fans were really loud....?
Yeah, I replaced all the supplied fans with the akasa ones and they're connected to a fan controller
