Climate control also includes heating and ventilation control, whilst air conditioning is only cooling.Ok stupid question time
What the difference between having Air Conditioning and Climate Control ??
Much thanks POBAir condition cools / heats the air with a refrigerant.
Climate control, controls the air conditioning to an exact temperature in degrees, and will constantly adapt the cooling / heating process to maintain the temp.
Climate control often comes with a dual zone feature allowing the passenger and driver to have different temperature settings.
Normal manual air conditioning is just always on at the setting you set based on the temp / fan speed.
FixedSimple solution, get an angle grinder.
Is it necessarily the fault of the Birtish public though? The first time I heard of the 'either/or' solution was with BMW on E36s.
[TW]Fox;20043957 said:There was no 'either/or' solution on the E36 - you could have both if you wanted.
Sunroofs used to be standard fit on a lot of cars until about the time when AC became standard fit, when the Sunroof was relegated to an options list and rarely chosen. You can still order one if you wish - but nobody does.
My 10 year old sunroof is leak free, as are both of my parents 15 year old w124 sunroofs.
But yes sunroofs do have the risk of being another bill, rust/leaks/motor failing.
Its because they leak
I know it depends on the system but I hate Climate control, I don't appreciate the process it uses to get there.
For example it might be 15c outside, which is nice enough but the car being set to say 20c it might start using heat to get to the desired temp, which would make me warmer.
