***Official Electronics Thread of Officialness (it starts off with lots of Nixie Tube Clock goodness
  • Thread starter Thread starter Aod
  • Start date Start date
Looks good and everything looks so clean and new - You should see the state of my 'helping hand' ;)
How many layers are in the board or is it a simple two sided affair ?
How do you folks see the antex xs25w?
I don't know it but being 25w it'll be somewhat more useful than the little 18w Antex irons.
That board doesn't look like it's multilayer.
Looking good! :D
It's funny how quickly soldering equipment gets to the "ancient and grotty" stage! :eek: :D
The board is a simple dual-sided board, nothing other than the traces on the top and bottom. it's very good quality PCB though, thick and stiff, well made, through-plated and the solder resist is very very effective.
Re. the Iron, see below \/ :) and here: http://forums.overclockers.co.uk/showpost.php?p=20039761&postcount=202
Yeah, the 25w will be better than the 18w but i seriously think that the Antex Irons are crummy, although many disagree and have been able to use them very successfully, i've never gotten on well with them.
Update:
Lots more components on the board now. Voltages tested and set. Almost ready to start putting the nixies on! That's the bit I've been looking forward to :P
Good stuff! What voltage did you set with the pot? I know the manual states 170v but I set mine to 168v to take it easier on the tubes, seems to work fine :)
Mmhmm, i know what you mean. i've not noticed any issues though.
when it's assembled, watch out for the solder tags of the Inductor and the rectifier diode, they can pack a nasty zap if you podge them with your finger :eek:
Toothy, are you soldering on the component side? :confused:
No, he's doing it the right way. some of the holes are quite generously sized, which along with them being through-plated can cause the solder to wick through the holes and blob-up on the component side :)
<edit>
After looking at it carefully it certainly does look like most of the components have been soldered from the component side... :confused: :eek:
Maybe he's just being really generous with the solder?
Occasionally when i got a bit too generous with the solder it blobbed up on the component side:
(Phone camera image! :eek: that was almost twenty watts of direct illumination! :D)
Hehe. Nah, I'm soldering from the back side. But like Aod said, the holes are quite large, so where the solder runs through component side I've just been touching it with the iron. Makes things look a bit neater :P
Ah, *phew* all fine then :) :D
does anywhere slel them pre made and ready to go?
btw does the actual board get hot? was thinking of incorperating one into my modem i think theres room inside :P
