Can anyone advise with regards to a better choice of juice? Ideally I am looking for something smooth and minty if that makes sense. I'm also happy to give something fruity a go (oo-er), but cant abide the thought of anything involving chocolate, toffee etc....
Also, does the amount of juice in the cartomizer effect the strength or purely delay the next refill?
For fruity stuff, it's expensive, but Pinkspot vapours are the best vendor I've tried. ECigwizard stock it. There's loads of lush fruit flavours. I bought direct from Pinkspot USA, bit cheaper.
Other good juices, there's a new juice called RYHi5 from vapourworld, I've not tried it yet, but it's getting rave reviews. I use RY4 from Ivapourelixir, they do a couple of different versions, and both are really good.
The amount of juice in the carto...you need to keep the carto wet, if it runs too dry, the carto will burn, if that happens, you gotta bin them. Keeping them wet (but not pooling) keeps the flavour going. When they stop crackling or become too hard to draw, then they need binning.
