OcUK H²Flo Liquid CPU Cooler - IN STOCK NOW! (now with benchmarks)
The unit is built, you just need to provide the fan and screw it into the chassis case. It's much the same as the H60.
You do not need to change or top up the fluid, as it is a completed closed, sealed unit, there is no where for the fluid to go too.
Mine has just shipped. Could've saved £2 if I waited another 8 hours to this morning to order, damn it! :p
Should be here tomorrow, I only live down the road but have got no transport to go pick it up myself at the moment.
are these worth it over the gelid tranquillo? I have a arctic freezer 7 pro rev2 I was going to use for the time being but the price of the tranquillo was getting me thinking about getting one, this is ~£14 more. I have a few different fans already which I'll try before buying anymore if the temps/noise isn't satisfactory.
Just in case its's of any use to people. I get similar (within a few degrees) temps with my kuhler 920 and this is half the price! Darn you ocuk! I ahve two vipers on my 920 in push and pull.
Yes, the performance is better than the tranquillo and the Freezer 7.
Exactly, hence the deal with the manufacturer :)
I like giving our customers cheaper products.
obviously but £14 better(before factoring in the price of a fan tho I have a few so no extra for the time being)? :)
edit: gave in and ordered, hope you don't sell it for sub £35 next week, bought the 128gb m4 for £140 and week later you had it for £135.
Would there be much difference in temps with this compared to a Titan Fenrir?
I7 860 @ 3.6GHz in a HAF-X case.
I would really like to know about comparison to the fenrir as well :-)
Also.. how noisy are the pumps please? (Shame you aren't doing a double height rad btw).
Personally I'd stick another fan to the rear of your freezer 7 pro in push pull. You'll be amazed at the difference and if you have one laying around then cost to yourself is £0
