The unit is built, you just need to provide the fan and screw it into the chassis case. It's much the same as the H60.
are these worth it over the gelid tranquillo? I have a arctic freezer 7 pro rev2 I was going to use for the time being but the price of the tranquillo was getting me thinking about getting one, this is ~£14 more. I have a few different fans already which I'll try before buying anymore if the temps/noise isn't satisfactory.
Just in case its's of any use to people. I get similar (within a few degrees) temps with my kuhler 920 and this is half the price! Darn you ocuk! I ahve two vipers on my 920 in push and pull.
That because you've got an overclocked 140W TDP chip that consumes over 220W under load at stock speeds!
Yes, the performance is better than the tranquillo and the Freezer 7.
I have the C3, so 125w.
Personally I'd stick another fan to the rear of your freezer 7 pro in push pull. You'll be amazed at the difference and if you have one laying around then cost to yourself is £0
