With regards the fin rot problem what would people advise move the fish over and treat in the new tank, or dont move the fish over until it has been cured?
Quick daft question, where does the bacteria for the cycling come from? is it already present in the water?
OK, just been to the fish centre, they have "bacteria" starter bottles, are these any good, or would you guys recommend the ammonia method.. Also their testing kits for everything were £30, seems a bit steep!!!![]()
thats cheap, my marine single test kits are £10 each.
I had a proper blonde moment earlier. I've just bought 2 ghost shrimp for my tank, and I noticed one was looking a bit too transparent. On closer inspection, i thought it was dead.
I was ready to scoop and out and go straight back to the pet shop, I was fuming........
Then I saw 2 other shrimp going about their business, was only a the moult leftover.
imo goldfish should not be kept in tanks, they grow to big and really need a pond.
if you are getting a new tank i assume you are also getting a bigger filter (i reccomend a Fluval External Filter 305 for a 300L tank), place one of your new filter pads in with your current filter to try and seed it.
also use the water from your changes to fill the new tank and run the new filter with this water to seed the rest of the filter media.
it should help speed up the cycle process.
Those bacteria bottles haven't got a great review over at fishforums.net
Really what do they say about them? Theyre pretty much what it says on the bottle so dont see why they could have a bad review!
FishForums said:go & find ammonia as all bacteria need food & oxygen, as do all life forms in one way or another. this is why we dont think the cycle in a bottle can work, theya are in a sealed container so no oxegen, the bacteria would perish within days without food, but are in a warehouse for months, then in your lfs for weeks before introduction into the tank.
If he has things like fin rot and other nasties, is it wise he's re-using that water in a new tank?
I got the new tank home last night which was fun and after inspecting it properly this morning it is obvious that the previous owner didnt look after it at all well. The inside is filthy and they have done a botch job of resealing the inside which I dont like the look of (good job it cost me next to nothing otherwise I would be fuming).
So I have decided that I am going to take the whole thing apart (as in to 5 individual sheets of glass), give it a good clean with a scraper, vinegar and isopropyl alcohol & then put it back together.
I have sourced some aquariaum grade silicone from a custom tank maker which will be delivered tomorrow & they use it on tanks upto 14ft so it will be strong enough to hold the whole thing together.
I have never done this before so it is going to be interesting and probably quite stressful (especially when leak testing). Will try to get some pics up later if I can or might create another thread about it if anyone is interested.
