Not sure I really agree with that Drunkenmaster, the pre-release hype (same as we have here for AMD) was that Sandy would happily do "5ghz on air".
The only person I recall saying it wouldn't was the Asus rep on the Hard OCP forum who said most chips were capable of 4.4-4.6 and abou 10% (I think) would do more...
I think Sandybridge > BD > Sandybridge E in terms of value. And I doubt BD will be that much better at overclocking than Sandy was/is.
Those samples that were benched would've been cherry picked. No doubt at all.
We are just hearing the same hype just from the other camp...
I hope BD is good though... That way I can upgrade...
AFAIK,  this was a bunch of unused chips handed out, stuck in systems and see how far they'd go. Its not hype when you can see it happen and see the results.  Intel send out one sample and have someone tell you how well it did.  AMD gave a bunch of overclockers a bunch of unused chips, and said had a go, and the overclockers gave us the results.
The other part being, again that the "hype" as you said around Sandy was that some would do 5Ghz on air, some do, most don't.  We've seen Bulldozers do 5.5Ghz, so again a 500Mhz clock advantage on what we've seen from Sandy.
Hence if the best few Sandy's do 5Ghz on air, by the same assumption the best few Bulldozers will do the same, 4.5Ghz is "easy" on Sandy's and it seems 5Ghz will be easy on a Bulldozer aswell.
The 5-5.5Ghz overclocking on air is all 8 cores working, almost all the overclocking was everything enabled, world records are done with as much turned off as possible, thats just the way it is, I don't much care for unsustainable overclocking, and even phasechange isn't particularly interesting due to the pain to set up and fairly high noise levels, vibrating compressors, need for decent amount of airflow and space.  But its pretty likely that while one module did 8.4Ghz, all 4 modules would probably have been fine at not much lower than that.  I'd be surprised if they couldn't do 7.5Ghz+ with all cores active.
Quite clearly with all cores active these are going significantly higher than Phenom 2's with water and phase, and Phenom 2 hexcores have done 6.9Ghz with everything enabled.
Theres not much to say they couldn't have done 8.4Ghz with all cores enabled, but end of the day it was a press event and went for a record, the 7Ghz Phenom/Intel hexcore benches weren't done in the same way, basically with limited time and tweaking.
Of course its also possible that around2v with all 4 modules drawing current that the mobo simply wouldn't be able to supply enough juice.
I was sure I read that they hit 7.5-7.7Ghz with all cores enabled but I can't remember where I read that.  Basically its about a Ghz ahead of Phenom at every stage, and so I'd expect all cores max overclock to be at similar distance ahead of Phenom, unless it becomes mobo current limited.
