- 17 Sep 2006
- Gloucestershire
Have you hit the horn yet when cornering?
lol not yet, although I can see how that could easily happen!
Thanks for the comments guys, proper chuffed with it
In my experience power through a corner won't lead to oversteer, but understeer.
I'd agree with that.
It depends how the car is setup and how much of a rhythm you get into and whether they tyres are hot.
The crash looked like driver error to me.
Try driving a club100 go kart in the rain. That is pure understeer, you have to use the throttle to get it to turn in. Then you have to make sure you don't use too much as it will spin.
Hit mine about 6 times. How much boost do you run op?
Lol that video is hilarious! A car like that does not appeal to me at allYou mean ilke this ?
Never driven the VX220 though, so no idea if the car is indeed challenging to drive, or if the above was just the owner running out of talent.
Made a thread. Its still on page 1Wait what? When did you get a VX220 and what happened to the S2000?
I've only driven the N/A Vx220 but it was the best balanced, most easy to control road car I have had to pleasure of driving. It was extremely forgiving in all situations. As I understand the Turbo is essentially the same in this respect.
Yes I have driven a VX220 (N/A) on a track. I found it the easiest most progressive road car I have driven on the limits. The car always gave you plenty of time to react, and would happily sit with the tail out at big angles even at higher speed.
The VX handles well but it's no Lotus.
The VX220 is more Lotus than the Elise![]()
The only times I've come close to binning my Elise on the road have been through understeer. I think Mr Walsh explains why so many cars are binned through 'oversteer' very well, the understeer is (not) corrected by added more and more lock, eventually the front end grips and has far more steering lock than is needed causing the back end to break away which is interpreted by the amateur driver as oversteer.
