Well im intrigued to see how SLI GTX580 do as they ran shockingly in the Alpha
Be advised, infrared? Never knew that was in the alpha.
On the initial alpha release, sli wasnt working. On the second release it was enabled. I was getting the following at 1920x1200, high setting.Sli was broken in the alpha, weird that crossfire worked though.
Single card, 50fps max
Dual cards, 80fps max
98% gpu usage.
Hmm, got MoH LE on steam, it says to look for the BF3 Beta key beside the CD key for MoH and it's not there?! Anyone else have MoH LE on Steam?
i did get an email saying my beta place is reserved for buying MoH LE back in July?
wtf is with the 'infrared' being green....
Its thermal.
It looks very similar to the scopes used in the PS3 co-op gameplay (skip to 2.50)An image intensifier is being used, not thermal or infrared, as I wrongly said.
http://www.hownightvisionworks.com/
A green phosphor is used in these applications because the human eye can differentiate more shades of green than any other color, allowing for greater differentiation of objects in the picture.
*Edit. Actually, second thoughts, it looks like a bastardisation of two or all three. The way soldiers show as being lit up, seems more like infrared or thermal. So not sure, anyone?
The AN/PSQ-20 Enhanced Night Vision Goggle combines image intensifier (I2 or II) and infra-red (IR, also called thermal imaging) technologies
God I waste my time doing some useless ****.
