AMD Bulldozer Finally!
Ok, can someone tell me how an 8 core CPU that can only score 5.95 @ 3.6Ghz in Cinebench R11.5 is impressive???
My 4 core unlocked Phenom II @3.6 Ghz gets 4.35.
100% more cores but only a 40% speedup....that does not seem very impressive to me.
Its not really 8 traditional cores. This for all intents and purposes is the next X4 design. They are just marketing it as 8 core for the marketing benefit.
Still, its not a total disaster i guess. I am curious as to the max stable overclocks and the actual IPC comparison.
I still think my next CPU is going to be an Intel. Guess it all depends on price. The fact that I'm going to need a new mobo whichever route I take makes it easier to jump ship this time.
So in that case, the 6 core bulldozer that i was interested in, is really only a true Tri-core?...:confused:..
..hmm, the more i look at these Bulldozers, the more the 2500K appeals...:(
Exactly. I am pretty sure that they will eventually introduce an 8 Module chip resulting in 16 "cores".
The 2500 and 2600 are both cracking chips, especially overclocked.
6 core bulldozer would have 3 modules with 2 cores in each module, total of 6 cores.
..then why is an 8 'core' bulldozer only as fast as a 6 'core' Phenom II..in Cinebench 11.5..?
Somethings not right here...and i hope for AMD's sake its another set of fake benchmarks...
What about this?
Doesn't look completely convincing... 4.8GHz with 8 cores the score is 7.8. With my 2600K with 4 cores (8 threads obviously) at 4.6GHz I get 9.04. Or is Cinebench Intel biased?
I know I said I didn't expect Bulldozer to be "that" much better, if at all, but I would expect the scores to be a lot closer, and at 4.8GHz it "should" be overtaking a 2600K...?
EDIT: Hang on... I have just noticed...
Why would an AMD slide showing the scores for Bulldozer chip have "Your System" as in Intel build... I call BS!
EDIT 2: Nevermind, it's the official screenshot from http://www.maxon.net/downloads/cinebench.html. It could be genuine I guess, but I would have thought in an AMD presentation they would have their own screenshot.
most likely fake results
im sure the 8 core BD as 4 modules with 2 cores in each module, total of 8 cores.
Nope, you get 6 full cores, don't worry. Each "module" (2 cores) shares some components, like an FPU (which isn't used very often nowadays) and a L2 cache (which helps with scheduling). They say that each module can reach 80% of the peak performance of 2 complete cores. Note that that's continuous peak performance. In reality, since all but the most efficiently-multithreaded processing tasks aren't continuous (there will be short bursts of peak processing demand followed by troughs of inactivity) and the workload will be asymmetrically distributed between cores, most of the time you wouldn't be seeing a performance difference between a 4-module BD chip and a "true 8-core" chip.
Looks like this basically:
I reckon the reason they're pushing the word "module" so much as a marketing term is because they still expect each individual BD core to be a bit slower than an SB core in terms of maximum performance (inevitably, since it only has half an FPU for one thing), so they want to get reviewers to think about relative performance in terms of 1 module vs 1 Intel core, in which case of course AMD will be made to look like it's ahead. I'm just speculating of course, we won't know for sure how they'll compare until we see some independent benchmarks.
What about this?
Haha, why would it also be OS X? a Mac...?
Looking at the results for Cinebench it would appear that clock for clock that bulldozer is slower than a Phenom II X6, now if that is true its pretty bad unless it either overclockers a lot or uses a lot less power.
AMD have done really well with there APU's recently but it is looking increasing likely that bulldozer will be a bit of a flop, I really hope these benchmarks are wrong.
you can tell those benchmarks are cherry picked, they compare the graphics performance to phenom 2 but don't say that the built-in gpu is used with it at the same time, nor do they show the games that its slower to use the built-in and 3rd party amd gpu.
I'd wait for benchmarks from review websites before you get your hopes up guys.
The teething stage for architectural overhauls is horrendous.
I'm more looking forward to a refresh, or just the 2nd generation of bulldozer now.
But Ivy bridge may be out...
something wrong with that cinebench score im getting with rig in sig 7.11 or 7.13 pts cant remember exaclty, with 1090 @ 4 ghz/2.8 nb.
