To all on TalkMobile what do you think of their service, 3g, etc? Sister looking to get the same deal. Thanks.
Yeah, mine keeps Bluetooth on when restarting the phone, however it doesn't show as a clickable notification. It's enabled still afaik though.
Guy,
Quick question but what's the best weather widget taking into account weather. I use GoWeather but in I'm in a call or no GPS it gives errors in the notification bar and I'm pretty sure that it is using battery for that even though I set it to only update once a day ...
What do you all suggest?
Free? I like free ... How is it on battery. I'd also like it to be 4x1 on widget size.
Will give it a look then, might still consider it ...
Getting use to this now, really like it so far. What satnav do you guys use? I had the latest tomtom on my iP4, whats the best one to get on the S2? I only really require UK maps. I have tried downloading copilot twice but neither worked. A link would be great too, if that's allowed?
