- 18 May 2010
- London
If there's no IPC increase, it's still a pointless CPU.
If there's no IPC increase, then it is indeed useless, but who said there was no increase?
That's my point, they wont?
1100T is £150 on ocuk ($189 in states). The FX-8100 could easily end up at that.
If they sit in the same price bracket, comparing isn't pointless at all.
I know exactly what you're talking about, stop being pedantic.
For what it's worth, I've asked a mod to delete the lot. So leave off.
There is nothing pedantic about it, because you have not removed the quote which you can do yourself, and yet you say you understand such a simple task.
I doubt BD will have reduced IPC as a Phenom 2. (If thats what your comparing too)
If that was the case, then the chip would be more or less useless on the desktop and would be better suited to server work.
So in that sense, I cant see it being true.
Come on, stop it now you're making a show of yourself, and I genuinely mean it with the best of intentions.
I had stopped beforehand, his last post was not needed and says one things while doing the opposite of what he said.
Back up his talk with his actions which he has not done.
As for making a show of myself is not something that i fear as long as people understand not to pigeon hole me because of the assumptions and common intentions of others, which happens all the time.
So, BD is an improvement, or isn't an improvement?
The 6100FX will still be called a hexcore.
Compare it to a 1090T, whatever, or a 1055T. If there's no IPC increase, it's still a pointless CPU.
I can't believe that people are bringing in the whole "IT'S NOT 6 REAL CORES" because BD isn't going to perform as they expected.
Honestly, I think it was coming across really badly from the beginning. I don't think any one really quite understands what you were going on with.
I don't think your reaction was at all warranted or justified.
I'm asking him to remove the quote, regardless how it came across and its that simple. if that was done then nothing more would have been said
I don't expect others to understand me personally, most people don't until they know me first hand and see the results for them self, once they do understand a small portion they then admit to the fact that they simply do not have the will power.
Are you having a forum breakdown?
