wasn't that an OS bug? what firmware are you running?
What extended battery is this? How much was it, and some more info would be nice.![]()
the new back cover sits almost flush with the little bump on the bottom (speaker area).
i've moved to touchpal keyboard which is pretty decent especially as it has both swype (which is slower as you only use 1 finger and is impossible with the phone on it's side to reach across the phone)
They should have just used that battery to begin with. The thickness claims were lies anyway as the entire phone isn't the same thickness!![]()
cm7 n66, keep getting black screen after ending a call![]()
You will find it here:
http://android.modaco.com/topic/346...sung-galaxy-s-ii-free-online-kitchen-testing/
Free one in beta/test at the moment but all worked fine for me.
When I first got my SGS2 I can remember that the stock text messaging APP was customisable, now after an update on Kies I can't see any settings for this? You could change the text bubbles colours etc. before, but not any more. I'm on KF4.
Any ideas guys? It's driving me mad!!!
...pics...
£23 delivered with codes, 2000mAh capacity (1650 is the original), 1mm extra thickness (in line with the lump at the bottom of the phone at the back).
Comes with a new back cover.
Will the official Samsung vented case work with the official extended battery & door in place?
