No, Any case that fits tight to back of the phone and especially if it follows the line of the "chin" at the base of the phone will not fit or fit poorly.
It has ~25% more capacity, how would that make it more efficient?
Is the battery available anywhere other than mobilefun?
The fact, 25% increase of 1650 milliamps is not 2000... Plus it charges faster watt per watt then the original.
Thanks for replying guys, everything is @ stock should i be looking at rooting my phone and using another rom?
Cheers
Try wiping cache and factory reset and re-flash, mine did the exact same thing.
I am right in thinking, aren't I, that removing and replacing (or changing) the battery while the phone is turned off, won't effect or change anything at all App wise... or will it?
Thanks!![]()
