easy i run it at 1920x1080 and get 60 fps constant
With what spec mate? Similar to mine?
Great! I've got i5 750, 4GB DDR3 1600Mhz RAM and Crossfire 5850s so I might get away with some Ultra optionsIs the open beta being released at midnight tonight?
how do i get onto a caspian border server?
Doesn't work
I have two PCs here, both i5s @ 4GHz, both @1680x1050. One with the GTX460 runs at high settings across the board, 2x AA, 4x AF and SSAO (motion blur disabled for the anti-suck) and gets 50-60fps outdoors an extra 10 on that indoors. The other is sporting an aging GTX260 runs at high textures with the rest medium, no AA, 4x AF and no AO (again motion blur disabled) gets 40-50fps. Feels nice and smooth on each -- much higher settings and you start getting the feeling of mouse lag. This is with the new beta drivers also.
- Got to Battlelog & Log on
- Sever Browser
- Filter
- Select Caspian Border Map & press view severs
- Lots of severs apear
- Try and get in one useing the password 'sexyelevator'
Its fairly lagy and you will need a lot of bandwidth to connect as most of the severs are in europe and the states, and are extremly busy. But give it a go, took be about 10mins to get on, and had about a round and a half of fun.
I run at 1920x1080.
With 5870 + amd 955 + 4 gb ddr 3 ram 1600mhz.
With high settings I get around 60-80 outside and inside over 100 easy
Oh my god. What a waste of money my 570 was![]()
