Caporegime
- 18 Sep 2009
- Dormanstown.
I was getting like 70-80 FPS on ultra and 1920x1080 VRAM about 950mb.
lastest beta m8which drivers scooby?
I want to try this on my work pc as I have the same spec as you here.
My 6950 and 2500k doesn't get near 40fps average on Ultra, never mind with 8xAA. I get around 30-35fps with the Ultra preset.
I find this odd really, the guy above with a 580 and 2500k says he gets just over 40fps and sometimes 80fps (i guess in the underground section). I mean, the 580 destroys the 5850, so I dunno how people are getting ~40fps average on mid-range cards when people on high end cards are just scraping past that.
My 5850 is clocked to 1GHz which helps.
a lot of people kidding themselves telling porkies in this thread.
Would i be mad if i got another 580 for BF3? I play at 1920x1200, spec in sig......
Outside my FPS pretty much crashed.
It is quite VRAM limited.
Solution I suppose is turning down AA.
Well that's what fraps says. After 1 game I got 20 min 72 max 38.5 average
Also the 5850 is not a mid-range card...it's the same range as yours...just a little older.
5850 certainly isn't highend, neither is the 6950, I didn't say it was highend, but its certainly faster than the 5850, and since its unlocked and clocked faster than a 6970, it should be faster still.
Oh yeah, the 6950's a mid range card.. Not..
The 6950's a high end card?
GPU: GTX580 stock
CPU: i5 @4ghz
Resolution: 1920x1080
Average FPS: METRO outside 35-40 fps inside 40-50
Driver version:280.26
Settings: Ultra, Antialiasing Post - Medium, MSAA - x4
Ok its highish end, not the fastest AMD card out. Its hard to classify AMD cards because the 6 series are very similar to the 5.
In addition to my post before, look at Frenzy:
He is getting the same FPS as someone with a 5850? Come on.
He's not using the beta drivers for bf3. (285.38)
