- 20 Mar 2007
- Norwich
Diet doesn't seem too bad Oxide, have you tried working out how much protein, carbs and fats you're getting each day? Aim for a 50:10:40 or 50:20:30 split or thereabouts. Basically high protein, high fat, low carbs. You seem to be on the right track here anyway.
Also I see a lack of lower body resistance exercise. The muscles in your legs are huge and make up a high percentage of your total muscle mass. The more muscle you have, the quicker you able to metabolise nutrients, the lower amount of fat you'll store. So get squatting!
Also as mentioned don't bother trying to isolate abs in any sort of exercise, it's just not how they work. They're there to offer support for your core, so you need to be doing exercises that recruit them as such. Look into Pallof presses. Also planks are good, but I see you're already doing them. But bear in mind you're probably not doing them correctly if you can hold in position for 1.5 minutes!
", but it actually makes sense.
