It would, but as stated you would need DisplayPort to get 120Hz output from the S27A750D. That GPU listed is very nice (2 - even better) but it doesn't seem to have DisplayPort.
DisplayPort 1.1a connector included
Thanks for the response PCM2 and Cleeecooo.
I am quite nooby also when it comes to monitors so I have a few more questions.
If I were to run the monitor at 120hz for example in battlefield 3 (or any other game) but not have a constant 120 fps would this have a negative effect?
hz and FPS are seperate (i think)
Second question if I were to use the DVI-D for 120hz could I use the HDMI connection for a console to connect to, would it work okay?
yes![]()
I would rather not link directly but you can access it by going on my website (click my forum name). To briefly answer your question as I'm not sure the technnicalities are really addressed all that well in the review; active shutter glasses basically give each eye half of the total frame output of the monitor. You therefore percieve half the usual framerate. This is exactly why 120Hz LCD technologies exist in the first place - to give the potential smoothness equivilent to 60fps which is much more optimal for 3D viewing than 30fps. Samsung's implementation is explored in a little more detail here.
