Is it possible to change tyre size?
31 May 2005
Alfreton,Derbyshire
I have a Honda CR-V which currently has the following tyre dimensions
225/60 R18
There are only a few different tyres in this specific size and the ones I'm after are out of stock everywhere at the moment. Is it possible to use a slightly different tyre dimension or is that a big no no?
Thanks
As long as you keep the same specification or better (ie speed rating etc.) then the only real issue is throwing the speedo out.
60 profile seems pretty hefty for an 18inch rim, is that standard for that car?
Edit, ahh the CRV is the 4x4 one, I was thinking of the CRX, lol! I would go with a 50 or 55 profile, 45 I think may feel a bit hard and crashy, especially for a car of that type.
Ok so next question is it legal to have different profiles front/back? I'm only looking at replacing the two fronts at this point in time
The cost doesn't bother me its the reviews of the ones in stock are poor and the ones with good reviews are oos everywhere!
That's what I was going to do but the two tyres I'm after are OOS at all the usual suspects. Thanks for the help though folks
205/65 would be a better, if you go down in width you go up in aspect ratio
odd size by the way
odd size by the way
Thank god somebody mentioned this.
As mentioned, the sidewall number is the % of the tread width.
225/60 = 135mm sidewall
205/65 = 133.25mm sidewall
Code:
Tyre code   Diameter  Circumference  Difference
235/55 R18  716 mm    2249 mm        -1.58 %
215/60 R18  715 mm    2246 mm        -1.65 %
225/60 R18  727 mm    2284 mm         0 %
235/60 R18  739 mm    2322 mm         1.65 %
195/65 R18  711 mm    2234 mm        -2.27 %
205/65 R18  724 mm    2275 mm        -0.48 %
215/65 R18  737 mm    2315 mm         1.31 %
195/70 R18  730 mm    2293 mm         0.41 %
205/70 R18  744 mm    2337 mm         2.34 %
All possible sizes that will have a negligible difference to speedo accuracy.
Found using calc at bottom of this page
http://www.alloywheels.com/tyrecalc.asp
Before changing tyre sizes its a good idea to phone your insurance company and check if they are ok with it. When I moved from runflats to non runflats on my car they said that was fine as long as I didn't change the size or rating of the tyre.
[TW]Fox;20246327 said:
Shocking advice, he has a 4x4 with high profile wheels and you suggest a 45 profile on the same tyre width!?
crv's are fwd with road car side walls
