Just checked my stock sgs2 also says no update available![]()
Got mine from Vodafone if that makes a difference? Not sure if different networks release the update at different times
Just clicked on "check updates" in settings on my stock sgs2 and it's just downloaded and installed 2.3.5
Got that glow thing instead of bounce now
Can anyone reply to this please, asked earlier in the thread and ignored:
What Im saying is that Samsung's software is crap and anyone who wants to defend their software is clueless.
Im not saying its a bad phone, the hardware is very good. But if Samsung had used their own OS or used winmo like before, this phone would be useless.
Which Build Number do you have now?
There seem to be several available at the moment, of which some are better (or later) than others.
Thanks!![]()
I just updated w/Vodafone over the air if its any help :
Came in two updates
Does this have over scroll glow, or over scroll bounce? I.e. if you navigate to ether the bottom or the top of a menu, does the list bounce back into focus or does a blue overlay appear?
Came in two updates
doesn't that "silent icon" annoy you when you've got it set to vibrate? it's totally unnecessary.
i'm sure it's only certain builds too, don't have it on 2.3.7
Is that regarding the '720p' comments Ive seen in this thread??You sure you don't want to even wait to see what the Prime has to offer?
