Hey folks,
Sorry for my late replies and addition to this thread but I got stuck in traffic:
Seriously though, a few things to catch up on. There is always a regular sale on at
http://www.fspilotshop.com/index.php ATM they have all FS2Crew product on for sale (seen as there is interest from the above postings) and it is worth checking out their Razbam range of aircraft as they are ALL selling for just $5 (about £3.30) each. Check their best selling list and you will see that Razbam atm is their highest selling aircraft, at $5 that is not surprising, so pick up a bargain (I would be careful though as some of Razbam's aircrafts, like so many others, are rather old and compared to many recent high quality addons and IMO just don't look visually appealing. I personally wouldn't install it on my sim even if it was free, but their Corsair A-7 volumes, the intruder & prowler plus their latest release, the kestrel is deffo worth a look)
Also worth mentioned in regards to add-ons, I recently got this
http://cr1-software.com/addons/ford-trimotor/ it is not stricly payware as it only asks for any amount of donation in order to DL this aircraft. I donated $10 (all going to a good cause) and had no regrets, it a lovely old classically modeled Ford aircraft, I would recommend it to anyone who enjoys flying some VFR. On the freeware front I would recommend taking a look at these guys
http://www.eaglerotorcraftsimulations.com/ a couple of nice freeware aircraft/heli for FSX.
On the matter of video cards, as I mentioned before in this thread, I used to run FSX on ATI cards but ever since moving to Nvidia, I would never go back to ATI when it comes to running FSX. The main 2 reasons, Nvidia can handle the Shader2.0 in FSX much much better, however, if you own an ATI then you should install Bojoto's Shader3.0 as they will give better results in your sim. Nvidia owners SHOULD NOT install shader3.0, I tried it and I felt it looked worse and it has its problems too. The other reason Nvidia has the edge with FSX is also due to the handling of large cloud volumes, I always noticed with my ATI cards that when it was very cloudy in FSX (especially if I turned up the cloud radius to @100 miles+) the sim would start to stutter fairly badly. I am NOT saying ATI cards are rubbish btw, I think they are great cards and with all modern games etc they stand side by side with the Nvidia range, but when it comes to a 6 years old written program called FSX, Nvidia is deffo the card to have.
While talking about Nvidia, use Nvidiainspector follow this link as guidance
http://www.simforums.com/forums/nhancer-settings-for-new-drivers-updated-v1932_topic36586.html and check this thread as well
http://forum.avsim.net/topic/338299-nhancer-and-antialiasing/
On the matter of tweaking and re-installing FSX, like many tips given in this thread, you will find you will get to know both your PC & FSX better after a certain amount of time. Some helpful things to do are 1) Fully backup your FSX directory from time to time in case you got a major ****up 2) regularly backup your fsx.cfg, scenery.cfg & dll.xml (worth spending time to getting to know these files really well!) 3) if your sim is running satisfactory, always be careful when adding changes to your PC, changing drivers or adding new FSX stuff can sometimes screw things up in your sim, so whenever you do change or add things, check your sim and be satisfied it is still running smoothly. Nothing is worse then changing and adding a whole bunch of things then finding out your sim is screwed cause it can be hell to fix it or do a roll back!
I know it is not possible for everyone, but if you have a PC dedicated to games or simming, us it ONLY for that purpose. Having a clean installed OS with just FSX will run much better and smoother then a PC that has tons of stuff running on both task manager and installed on a full HD! The less background tasks that are running, the more CPU & memory you will have to run FSX.
A note on AI traffic, whether Traffic X or other program, if you switch on your AI slider from 0% to 1%, your CPU will already take a hit. Depending on AI program/models & your hardware setup, switching on AI will hit your CPU thus your FPS. If you do use AI, try to experiment what a good % of AI is for your setup. On average between 20-50% is acceptable for most setups, especially at very large airports, this is more then enough for most PCs. On more powerful PCs, I found that switching between 50% & 100% hardly makes a difference unless I am in the middle of a very large airport, so I tend to change my AI slider on the go in order to maintain a balance between AI & FPS. (btw changing your traffic slider in setting during a flight will NOT change your TBM from 4096 to 1024, only if you change the other TAB settings!)
Quick word on add-ons, IMO the most essential payware add-on has been and still is REX2.0 overdrive, full stop! If nothing else, just buy that and you will enjoy your sim 100 times more.
Last but not least, I managed to find one of my first ever screen shots, before all these tweaks/addons/mods etc. It really shows how much more 'basic' my sim was when I started.
Cheers all.
