Man of Honour
- 16 Jul 2009
- Edinburgh
Hey guys, just wondering if any of you have upgraded from your 3810/8371 to anything new and if so what did you plump for?
Mine is still going strong, used everyday for the last 12 months, using it now!
Hi,
really like the new BISO dragonuk found.
But I wonader are there any news regarding the small size SSDs that could be installed besides the standard HDD?
The Kingston - SSDNow V-Series 30GB still costs 80 EUR or more, which seems very much for such a small and slow SSD. Would be great if other SSDs would work also as I feel my machine gets slower and would like to speed it up. Any experiences with other SSDs??
Cheers
playagiron
There is finally an alternative and a very good one at that!
These guys sell very fast half-slim SSD all the way up to 128GB:
http://www.mydigitaldiscount.com/mydigitalssd-half-slim-sata-ssd/
and here is a review from a user:
http://forum.notebookreview.com/sol...half-slim-sata-solid-state-disk-reviewed.html
The ATI graphics are overclocked by default when you install the bios.
If you get a program like "GPU-Z" when you run it you will see the ATI graphics are running at 550mhz core and 750 mhz memory.
The default is 450mhz core and 600mhz memory.
Don't forget you can overclock the cpu to 2ghz instead of 1.4ghz by overclocking the fsb to 250mhz instead of 200mhz.
You just run this exe and its done. Simple. You have to run it everytime you restart your PC though.
Download - http://www.mediafire.com/?k5lz3qaijq8wunm
After a bit of advice. Had my TM8317G since start of last Dec. Just turned it on today and noticed that just the bottom left is darker than the rest of the screen. I can see the start button but it's just darker than the rest of the screen. Is this part of the backlight that's stopped working?
dragonuk,
How did you get it to 2Ghz? As far as I am aware given the multiplier of 7, the max speed should be 1.75Ghz?
good find shame that UK shipping is $35 for a laptop I use irregularly the 40 quid of the drive ok but another 20 for shipping that's hard to justify... I wish I could justify it! maybe a ssd for my desktop first would be a start
Hey guys, my Timeline 8371's battery suddenly stopped working. I can only use my laptop with the AC Adapter plugged in. I've tried loads of things on the net, but I'm not sure if it's that 1.28 custom bios I installed that's causing it. Can anyone please help? If not, i'll wait a few days to make sure it's not a temporary thing and then i'll buy a new battery. Do you recommend the 9-Cell batteries on eBay or are they not trusted?
