	6950x3
This is a 20hz core OC
I upped this to 80hz stable to try and get on the top 10, was at 130 average FPS on second to last scene, (Last two scenes are best fps gainers for me, as I get 260+ on them) and my display driver crashed x.x
Going to try again
6950x3
Going to try again
How are the temperatures on your HD 6950's now?
	I currently am using the beta 285.38 drivers for my setup. And i use ungine 2.5
I did a test with my sons PC i5 750 @ 3.7Ghz, he has a 560Ti 900 core 1800 shader and i think his score was virtually the same.
O/Cing your i5 2500k will help score a few more points![]()
	Wow, that is pretty nice. What sort of temps do you run (under load) on those 3?
Atm, the one next to the processor heat sink hits 90ish max
the other two hit 50-70 max
Pretty good temps for trifire, not that pleased about the burn from the heatsink, but it's ok.
I haven't had a chance to run them with a higher clock, MSI afterburner crashes instantly if I try and OC the cold ones.. no apparent reason, if I turn off extended OCing I can clock them fine, but then I can't clock the 3rd one.
Thats insane for a laptop![]()
It did likely cost well over £2,000 and a desktop less than half the price could beat that score.
