Erm, yeah... if only my home WiFi was already as fast as my phone can write to the SD card... oh wait!
How does it work ? , just now I plug in the USB cable then drop my music/docs on the phone. How do you do that over WiFi ?
How fast can the s2 write to cards? the most i've seen out of my wireless is 30Mbit which wouldnt saturate a class 6 card (6MB or about 48Mbit). Maybe the s2 isnt capable of writing that fast?
Transferring the actual mp3's? How about Google Music? You upload music from your PC, and either stream it on your phone, or cache it on the phone.
No need to connect.
http://hemorrdroids.net/google-music-in-the-uk/
I have an invite left if you want it.
Kies sucks!my 2p's worth
- don't bother with kies, i used once and binned...
- if you do use kies 'untick' load at start up as it runs like a dog on any pc
- as for launcher there are better ones, but for some reason NONE seem quite as zippy at
touchwizz, someone said they all need to be redone and optimized for duel core phone.
Yeah Kies sucks, but Kies Air is actually quite useful. It doesn't always load up in my browser, but after a few goes it works nicely.
I'm still using Touchwiz 4 launcher, surprisingly good on the SGS2. I was using it on my SGS for a while but it runs a lot better on this phone. Don't see the advantage to changing it really. Although still can't sort app drawer alphabetically!
The 'must do's' for the SGS2 are probably get a decent ROM on and root it. Beyond that not much else, totally depends on how you use Android and what you need. The beauty is you can set it up how you like really.
There's a modded Touchwiz .apk floating around somewhere on XDA that allows 5 icons in the dock and sorting the app drawer aphabetically.. can't find it though. The only one I found was for the SGS 1 and apparently it force closes.
How do you display your mobile operator on the homescreen?
yeah i wouldn't mind trying it![]()
I'm thinking of ditching the 4s to go to this mainly cos of the flash player do you guys think it's worth it? I will buy a ipad2 so I don't see the point of owning a iPhone and iPad?
P.S Is it the best android phone out ATM? Or should I wait for a new one to come soon? I heard the galaxy nexus is not as good as the s2
Why? Does the flash player not run smoothly?
It's also that the battery life on ye 4s is poor.. Used google maps yesterday from 50% battery within 1 hour battery went dead?
And also is there any point owning a iPhone if u got a ipad2?
It shouldn't be that bad. I doubt the Galaxy S II battery is going to be any better.
Not sure i'm 100% happy with my SGS2.
I might sell it and keep the sim.
