F1 2011 no xfire support at all, Rage no xfire support, BF3 no trifire support?
which cards have been running BF3 better ATI or Nvidia?
We experienced stuttering and jerky behavior with Radeon HD 6970 CrossFireX. I wouldn't say that it is "MicroStutter," it is outright "stutter" or a "jerky" feeling as you play. As you move through the map you can see and feel that it is not smooth, not consistent, and you can visually see this as you are walking. There is a lot of straight line walking during the first few minutes of the map, and it is very easy to identify and breaks the immersion of the gameplay. We started with the GTX 580 SLI and experienced smooth gameplay, and then when we installed HD 6970 CFX to compare performance the constantly laggy experience was immediately noticeable.
The jarring behavior is so bad that it is distracting to gameplay, and is not a configuration I would use if I were playing BF3. After having used both GTX 580 SLI and 6970 CFX in this first mission, I can easily say GTX 580 SLI is the better experience and what I would use when playing. AMD has a lot of work to do with CrossFireX, while the performance is there, the smoothness and consistency is not even closely competitive with SLI configurations. Now, it could be a simple in-game graphics option that is causing the issue, but it is something we will have to look at closer as we play the game more.
Im playing at 2560x1600 ULTRA settings and getting solid 60 fps (vsync on), But did have to increase page file and Vram is on the limit.
Could do with 12gb of ram and 3gb gtx 580 cards![]()
Quick irrelevant question: I have a ATI 5970 and BF3 struggles at ultra (or high with AA) at 2560x1440, i'm considering upgrading but can't decide between a few different cards.
3GB GTX 580, 2GB 6970 or 6GB 6990?
That game doesn't use more than 2.5GB RAM according to Windows Task Manager, how much memory have you got? I've got 4GB DDR3 1600Mhz
I get anything from 30 - 45fps, using these settings..............
Loads of fps (80-110 easy) but bad stuttering. So far I've tried 11.10 v3 with and without the cap3 and it's pretty much the same, maybe slightly better with cap3 but still pants. Vsync makes it worse and it seems to be worse on the bigger maps. The one in Paris that isn't metro seems to be fine. Most likely crappy drivers but I'm not ruling out problems server side. It'd not VRAM because it does it when VRAM is not at it's limit.Running lovely here, everything on max @1080p:
6950>70 Crossfire@950MHz, 1350HMz, +20% power tune, [email protected], 16Gb mem, Crucial M4 128Gb for the OS and a Force 3 for BF3.
11.10 Preview 2's(preview 3 gave me issues with other games so I went back) and cap 3
Simply sublime, lowest I've seen in mp was about 58fps to the highest about 140+ fps, very little to no screen tearing as well!
Performance shocked me to be honest, I wasn't expecting this kind of fps!
