Is that it now, just turn the thing back off, no need to have anything else running? Just play the game as normal now?
yes
Disable UPnP in your router settings.
Anyone else get a sort of lime green flash across the screen randomly every now and then? literally for 1 frame every 30 seconds or so randomly?
We need to all get on mumble or something and get playing together!![]()
It doesn't work, i cant bind my middle mouse or shoulder buttons.
So, do we have a platoon? Searched OCUK and found a group with 0 members and 1 fan...useful!
Ok just to make sure I done this right and don't need to do anythign else:
followed this:
http://forums.overclockers.co.uk/showpost.php?p=20381411&postcount=28465
and
http://forums.overclockers.co.uk/showpost.php?p=20380661&postcount=28422
And I have passed the release check!
if you want to play online go onto battlelog. log in. then remove proxy etc.
or if not set origin to offline and campaign. remove proxy
Do the new nVidia drivers improve anything major? I really CBA faffing with drivers again this month![]()
On the edit profile section on battlelog, theres an option to add your tags, just type OcUK. The brackets will be added automatically.[OcUK] daaaavvveeee.
I have your tags
Also how do you add the OcUK tag to your name? I'm in the Platoon.
Using the Korean proxy and have changed my time zone to match, and Origin still says "Unreleased". Closed and re-opened Origin, rebooted, etc. Nada.
Disappointed Kev![]()
